It is currently Mon Jul 21, 2025 10:38 am
PostPosted: Tue Jan 30, 2007 1:09 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
What problems might I encounter if I put a Martin 12 fret neck on a L-00 and a 24.9 scale? or should I use standard Gibson scale for L-00
PostPosted: Tue Jan 30, 2007 1:26 am
Go for it...you might have to tweak the bracing and BP position. Make sure you address that before you take the plunge.
PostPosted: Tue Jan 30, 2007 3:17 am
First name: Larry
Last Name: Hawes
When I first saw the L-00 I thought it would make a great 12 fretter. As was said above just layout your bridge plate and bracing so the bridge plate will fall in the proper place with your sclae length and the 12 frets and you should be fine. You might have to adjust your x-brace (if you use one) angle because the bridge and bridge plate will end up further down into the lower bout with the 12 fret design.
Thank You and Best To All
PostPosted: Tue Jan 30, 2007 6:41 am
Last Name: Johnson
State: CO.
Could you please tell me what angle of x brace should be?
I'll use bridge location jig for correct placement of bridge and saddle?
Users browsing this forum: Bing [Bot] and 19 guests
